Low oil warning issue..but there isn't.
Yesterday morning I had a low oil warning light go off on my 99 C5 coupe, I checked my levels & put in half a quart & & was still showing low. I went to stock up on oil at my local Pep Boys, checked my level & pul a quart in. Went on my way got about 10 miles from the house, thought all way well & good, then got the low oil warning AGAIN. Pulled over & checked the level, put in a half & turned around & went back to the house, I didn't want to take chances. The exhaust wasn't wet & wasn't blowing any smoke. Made it back just when getting into the driveway warning went off again. At this point I was running late, changed vehicles & went on my way would look into this later when it was cooler.
I checked my levels this morning & I'm overfilled, the oil is getting trapped somewhere. I hope this isn't critical I can't afford a new engine right now.
I'm also trying to find a shop in the DFW area, I'm in west Fort Worth. Looking for shop recommendations please.
JB Corvettes in Richardson
Quality Motorsports in Lewisville
you need to drain some of the oil out to make it the correct level with the dipstick or just change the oil and refill to correct level...
How did you check it... running...hot... cold... did you kill it and let it set a while before checking? I don't think there is anyway the oil would be getting trapped and not returning to the oil pan... POSSIBLE you couldn't see where the level was... some have a hard time with that...
That is extremely overfilled, you got to drain it. Could just be the low oil sensor needs to be replaced.
That's ok... we all screw up... just hope you didn't screw up again BIG TIME taking it to the dealership...it's more than likely the SENSOR... very simple... hopefully they don't rape you
Any update
I got the car back, the low oil sensor was stuck. thanks for all the advice and concern. Big thanks to Quality Motorsports for sorting it out.
Quality Motorsports does not sound like a dealership... more like a specialty shop... GLAD you got it fixed and thanks for posting your outcome
TXWMH (06-23-2016)
