Ground strap iron block
Old Jun 20, 2016 | 02:50 PM
mustangracer's Avatar
mustangracer
Default Ground strap iron block
Going from aluminum to iron block. On the aluminum motor I have 2 spots one on each side of block for ground straps. Now on the iron motor it does not have these spots, anyone who has done this swap where did you move your grounds? Thanks
Old Jun 20, 2016 | 04:52 PM
helga203's Avatar
helga203
You can putake the ground wherever you want.
Old Jun 20, 2016 | 09:52 PM
ajrothm's Avatar
ajrothm
You can ground the strap to the back of the head. There is already a factory ground bolt/wires there.
Old Jun 20, 2016 | 10:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would use a bell housing bolt to ground the BLOCK. If you use the head as a ground, you are using the head bolts as part of the circuit. Poor head bolts don't need any more burdens to deal with!!!
The single bell housing bolt connects directly to the block and seems like a more robust connection directly to the block.
Just My honest opinion.
Old Jun 21, 2016 | 04:25 AM
Rob 02's Avatar
Rob 02
You can buy strap material and soldier connectors to it if the original is too short.
To Ground strap iron block
