Rocker upgrade?
Old Jun 22, 2016 | 01:00 AM
Ehastings32's Avatar
Ehastings32
Default Rocker upgrade?
Was wondering how much power are stock rockers good for on an 01 ls6. Also what rockers are the best bang for your buck.
Old Jun 22, 2016 | 01:49 AM
StingrayRebel's Avatar
StingrayRebel
stock rockers are fine, just upgrade the trunions and you should be good to go... not really sure on their power limit, for what it's worth I've made 800+ on stockers
Old Jun 22, 2016 | 03:49 AM
Ehastings32
Awesome! Saves me some money. My plan is to be around 800 by the end of the build. Would a monster can play a factor though?
Old Jun 22, 2016 | 06:47 AM
vettenuts's Avatar
vettenuts
You asked about rockers, but are talking high horsepower. For the record, the need for different rockers is not related in any way to HP. If you go to aftermarket heads with bronze guides, stock rockers should be replaced with rockers where the sides loads can be minimized or you will be facing high valve guide wear. So if that is the case, than you may need to re-evaluate as other parts are selected. You can have different guides installed so stock rockers can be used however.
Old Jun 22, 2016 | 09:17 AM
Ehastings32
I am using stock 243 heads but putting all new internals. Replacing all but valves. Was asking about the rockers to see if I really need to replace them with something better. The cam will be a street strip blower cam. Not sure what the specs will be but springs, rollers, and push rods will be changed.
To Rocker upgrade?
