Finally solved loose steering. It was the steering column!
I had about 3/8" free play in my steering. Really bothered me when on the highway. I went through hell trying to diagnose the problem. I checked everything, including suspension components, steering rack, Intermediate shaft couplers, and intermediate shaft. I even replaced my steering rack and intermediate shaft.
Well, it was the steering column! I never heard of this happening. Either the column tilt U joint or the collapsible steering column shaft has developed some free play. I replaced the column and all is better know!
I diagnosed this by disconnecting the intermediate shaft and used a vice grip on the end of the steering column that protrudes into the engine compartment. I accessed the end of the column by removing the left inner fender access panel. I could then reach my steering wheel and slowly rotate the wheel to detect the free play.
Replacing the steering column was a PITA because of the tight space under the dash. My back hasn't recovered yet from the contortions I had to go through to access some of the wires and bolts.
Car has never been in an accident and has only 50K miles on the ODO.
1/4 mile/AutoX
Received 19,209 Likes
'20-'21-'22-'23-'24
Good deal that you finally got it figured out. Sometimes it does take a lot of trial and error.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Maybe do a little dissection on that old steering column and prove out the actual failed component.
You may help others and you may actually find a way to FIX the issue.
That's how I figure out what fails and cool ways to overcome the problem for little or no expense.
BC
BC
Tron Z (01-03-2024)
bringing up an old thread, I am having a similar issue and not sure I have been chasing it for a year and came across this. Anyway to check your intermediate shaft to see if it's bad?
I also have about 1/2” free play in my steering and I’ve gone through everything except the steering column at this point. I’m going to check it out today. Did you order a used steering column or is there a place to order new ones online?
Thanks,
Chad
Thanks,
Chad
Thanks for posting. I'm sure that I've heard of stranger issues at such a low mileage, but I can't think of one at the moment. As @Bill mentions, it would be very useful to determine the exact point of failure, should you have the time to take a deep dive into the column.
Cheers!
Cheers!
When I first got my C5 at 31k there was play in the steering wheel. It turned out the coupler bolt to the steering rack was loose. Tightened the bolt and no play.
Similar experience. Any number of fasteners or couplers can work loose. Steering columns are basically all the same, troubleshooting the column starts checking the intermediate shaft between the firewall and steering rack. You can check the joints at either end of the shaft by twisting it with your hand. I've seen lots of these go bad. I would also check the column nut under the airbag. Even though the steering wheel is a press fit and you'd think the nut doesn't do much, I've seen these nuts back off enough where the innards of the column are no longer under compression and will give you the wiggle you are seeing. I've also seen tilt steering pivot pins work loose, a quick twist with an allen wrench will tighten these up.
Dads2kconvertible (01-08-2024)
Steering column brace was lose
