Convertible Top Latches
Old Oct 1, 2016 | 08:56 AM
2ndvett01's Avatar
2ndvett01
Default Convertible Top Latches
2001 vert: how is the convertible top latch tension adjusted?
Old Oct 2, 2016 | 09:45 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Most likely by replacing the weatherstrip on the front edge of the top. But I am guessing here. I did a top replacement and never had to change anything. Fact is, I don't think the latches are movable at all.
Old Oct 3, 2016 | 01:19 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
The part of the latch attached to the windshield header had 2 10 mm bolts and each have about an inch of adjustment. The bolts are under the inside moulding.
To Convertible Top Latches
