hper turn signals
Old Dec 7, 2016 | 11:02 PM
ehuron's Avatar
ehuron
Default hper turn signals
I broke the stay on switch on my hazard switch (had to hold button in for them to flash). I had it repaired or replaced, don't know what they did. The 4 way now works fine, normal blinking, however now my turn signals go into hyper flashing. No bulbs are out. I took it back, but they don't seem to know what it is. They are going to check, but I would like to have an idea what they will be talking about. Thanks
Old Dec 7, 2016 | 11:07 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well if they don't know what they did how can they fix it?
Old Dec 8, 2016 | 06:49 PM
ehuron's Avatar
ehuron
Default hyper flash
Thanks for your help. Why does somebody like you even respond to a question? If you had a bad day at the office, don't bring it to the forum.
Old Dec 9, 2016 | 02:09 AM
Rob 02's Avatar
Rob 02
The flash is in the switch. What ever they did, was wrong. They may have replaced the switch with a defective one. You would think they would check first.
Mechanics that don't have experience with Vette's shouldn't be working on them IMO. I wouldn't want someone getting their learning experience by experimenting on my car.
I hope they work it out for you.
Old Dec 9, 2016 | 04:49 AM
ehuron's Avatar
ehuron
Default hyper flash
Thanks, at least now I have an idea. They actually are the premier Vette shop in the San Antonio area. I think you're most likely right about it being defective.
Old Dec 9, 2016 | 10:49 AM
Velocity_Vette's Avatar
Velocity_Vette
Per what Rob said above, the flash mechanism itself has operation that is part of the hazard switch. Because of this, even when the switch itself is not pressed or used you are still getting current through it from the activation of the multi-switch (your turn signal/head lamp stalk) and brake lamps, which combined with the heat from the dash and electricals is what eventually begins to wear the switch down. There are plenty of good reference shots online of switches that have near-melted contacts from the heat. It's not the most ideal design since so much load traverses through the relative tiny body of the switch and any definitive issues can be difficult to pin-point.
I'll be honest I'm not exactly sure why you would have it "repaired" since the switches are relatively cheap - at the most it's a $30 part. When you buy the switch you get just the switch body itself; the old button is re-used. The biggest hic-up always seems to be people are daunted by taking their dash apart. It can be a chore to get the switch body out of the HVAC housing but it's do-able within an hour or two of work by yourself.
Old Dec 9, 2016 | 01:52 PM
Rob 02's Avatar
Rob 02
I guess anyone can make a mistake. It is hard to be familiar with every problem the car could have. Here you have the benefit of everyone's experience.
Old Dec 9, 2016 | 06:32 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
This may sound a little crazy, but mine will RARELY do what you are describing....the way I fix it is to firmly (but not too hard) hit the dash JUST above the hazard switch a couple of times or so, and it usually goes away I've only had to do it a handful of times since it became an issue about 2 years ago...but, hey, it does the trick (which of course, if that does work for you DEFINITELY means the switch is the issue)
Old Dec 9, 2016 | 07:19 PM
ehuron's Avatar
ehuron
I thank everyone for their input. I went back to them today and at least sounded that I knew what I was talking about. We both agreed that, since it was a new switch (not repaired) that it was probably bad. They ordered a new one. I feel a little sorry for them since I have read what is involved with installing again. However, I would have tried it before putting everything back together. But that's probably because I'm a novice and wouldn't want to do it again. I will try that hit the dash above it, just for the heck of it, but will let them put a new one in. By the way, Velocity Vette was right, they charged me 2 hours. Anyway, I'm good to go.
To hper turn signals
