8 Bolt LSA Crankshaft with C5 Flex plate?
I just realized that the LSA crank in my new motor is an 8 bolt crank. Therefore my stock flexplate wont bolt up to it. Does anyone know if you can bolt the torque tube coupler hub to an 8 bolt LSA/LSX flex plate? Based on the pictures I've seen it almost looks like it can be done.
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Good question. And I'm sub'd for an answer as well.
Have you called RPM Transmissions? They've seen a lot of different setups come through their shop. They might have an answer.
I plan to use an LS9 crank in my turbo build. I believe that has a 9 bolt flange.
If the cost of any oddball adapter is more than the difference in just buying a standard flange forged aftermarket crank, then I guess I'd buy aftermarket.
