C5 Z06 180 degree header build thread
Old 02-20-2017, 04:57 PM
  #101
Tinmatt
Tinmatt's Avatar
Originally Posted by danh52
Great job of fabrication so far!
I had to laugh at the last picture showing the weld table and the paper backed insulation.
Thanks. I've been meaning to finish the garage walls for a while now but this project is more fun.
Originally Posted by v8srfun
That is not a issue with tig
Correct, no sparks when tig welding.
Originally Posted by nsogiba
Probably from grinding (most likely) or MIG
It's actually from constantly pushing other projects to the back of the bench... so many projects still needing attention in the garage.
Originally Posted by The Chev
All this talk about the insulation and no one mentioned the soda can bottom with the hose in it? I'm guessing that is from the shield gas.
Nice!
Exactly, beer cans fit 2 3/4" tubing perfectly. I should have mentioned all the welding is being done with an inside purge.
Old 02-20-2017, 06:01 PM
  #102
Tinmatt
Tinmatt's Avatar
Finally onto the primaries. I started with #2 as it has the longest path to the collector. The #1 primary is actually further away, by the width of a connecting rod, from the collector but because the spark plugs angle forward on the driver side and backwards on the passenger side, the #2 had to go around it's plug unlike #1 that can take a straighter shot.
It came in at an acceptable 38" long while leaving room for the rest of the passenger side pipes to make their way to the collector at the same length. The #8 primary fought me quite a bit. Finally, the third routing option ended up getting both the length at 38" and leaving room for #4 and #6 to make their way.
The first half of #8
And how it fits around #2
Old 02-20-2017, 07:02 PM
  #103
Sam Handwich
Sam Handwich's Avatar
Nice!
it WAS mentioned. By the member who posted the picture.
Old 02-20-2017, 07:48 PM
  #104
v8srfun
v8srfun's Avatar
If the op does not have a high quality camera / microphone setup someone with one needs to get some video of this sound when finished.
Tinmatt (02-20-2017)
Old 02-20-2017, 08:09 PM
  #105
Tinmatt
Tinmatt's Avatar
I would more than welcome anyone in the central Ohio area with some decent recording hardware to capture the music I'm hoping she makes.
All i have is an iphone in which to attempt to record the sounds. I'm considering an external microphone for it, if anyone has suggestions as to one that excels in recording exhaust notes at short distances, please speak up.
Old 02-28-2017, 07:51 AM
  #106
nsogiba
nsogiba's Avatar
I have no doubts you'd be able to find somone willing to record this in detail. You should show up to a local Cars and Coffee when it's done, you'll get plenty of attention.
Tinmatt (03-01-2017)
Old 03-01-2017, 12:14 AM
  #107
Rob 02
Support Corvetteforum!
Rob 02's Avatar
Regular long tubes aren't tucked up so nicely.
The header work on a C5 corvette is a tight squeeze.
Awesome work!
Old 03-01-2017, 01:09 PM
  #108
YYZ06
YYZ06's Avatar
Folks who can come up with, visualize, and actually produce this kind of stuff blow me away. The pictures are great and I appreciate you describing all that goes into the fabrication process. Hats off to you, awesome work.
The following 2 users liked this post by YYZ06:
Pounder (03-01-2017), Tinmatt (03-01-2017)
Old 03-01-2017, 01:15 PM
  #109
Pounder
1/4 mile/AutoX
Pounder's Avatar
Received 2,082 Likes on 1,635 Posts
Old 03-01-2017, 01:36 PM
  #110
feeder82
feeder82's Avatar
how are you going to remove those headers once they are all done? or will you have to cut them
Old 03-01-2017, 03:32 PM
  #111
Tinmatt
Tinmatt's Avatar
Thanks again for all the kind words
A little more progress.
O2 bungs welded into the collectors. The upper collector being so tight to the tunnel plate required that I cheat it's position slightly in order to maintain a downward angle of the sensor to prevent damage due to condensation. I was able to get a 5 degree downward angle by placing the bung off center and grinding it at both an angle and radius.
And a pile of passenger side primary pipes welded up and ready to go back into position to tack weld to the header flange. They came in at 38", 38", 38 1/8", and 37 3/4" in lengths. Crossing my fingers, toes, legs, eyes, and anything else I can in hopes that the header, when assembled, will slide out of the engine bay without major surgery. The #4 primary is run close to the side of the block making the header pretty wide in it's mid section.
Old 03-01-2017, 03:35 PM
  #112
Tinmatt
Tinmatt's Avatar
They will be almost as easy to remove as any other pair of long tube headers. There will be two headers as normal but without collectors welded to them. The collectors will be slip fit with tabs that either bolt together or are secured with springs, not sure which yet.
Old 03-01-2017, 04:54 PM
  #113
feeder82
feeder82's Avatar
O.K., it's just the length of the primary tubes that has me wondering if they will come out. Great project
Old 03-01-2017, 05:58 PM
  #114
Roddy13
Roddy13's Avatar
Beyond Impressive!
Old 03-02-2017, 02:44 PM
  #115
Tinmatt
Tinmatt's Avatar
Major fail #2. Got all the primaries tacked to the header flange and short of removing the cylinder head, there is no way it would come out in one piece. I broke loose the #4 tube and jacked up the passenger side of the engine to get it out.
Looking at it on the floor and remembering the sticking point when removing it, I figured it was actually the #8 primary interfering with the A/C line, not the #4. So I made a quick little jig to hold the primaries in position at the collector end to allow me to tack #4 back in place. Then I removed #8 from the equation and tried to slide the 3/4's of a header in place. No dice. It's just plain too wide in the area around the starter and A/C line.
New plan of attack. I have more room directly under the flange, near the block between the motor mount and starter to snake the pipes around and take up the distance #4, #6, and #8 need to equal #2's length. So, I will run the four primaries from the collector tight to each other all the way past the starter and A/C line pinch point and then start throwing bends where they need to go to get my equal lengths. This will also allow me to build a good percentage of it on the bench which is far easier than under the car.
Old 03-11-2017, 08:53 PM
  #116
Tinmatt
Tinmatt's Avatar
Passenger side, version 3.1. Got to this point and once again, no go.
Even with the starter removed and the motor jacked up on the passenger side, she wasn't going in.
Time for slightly drastic measures. I cut the first half of the #6 primary out to allow the #4 primary to take it's path. Then the #6 was directed to the outside of #2. Everything came in within 3/8" of the target length. As a huge bonus, as I was sliding into place for it's final test fit, it appeared it might slide by the starter. Bolted the starter in and the header slide right by! No jacking of the motor or starter removal required. Only the large positive wire to the starter and ground wire to the block need to be removed.
Version 3.2, the final version!
Only thing left on the passenger side is to weld it out. The driver side should go much smoother due to the larger area to work in, the favorable angle of the spark plugs and the lessons I have learned on this one.
The following 2 users liked this post by Tinmatt:
C4ProjectCar (04-26-2021), VFR RC46 (01-29-2020)
Old 03-12-2017, 09:18 AM
  #117
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
To C5 Z06 180 degree header build thread
Old 03-12-2017, 02:40 PM
  #118
The Chev
The Chev's Avatar
Wow, fantastic! I know that is a sigh of relief.
Old 03-12-2017, 05:18 PM
  #119
SuperTom
SuperTom's Avatar
I really wish I understood everything done to make this happen. Hope it sounds amazing!
Old 03-13-2017, 10:05 AM
  #120
nsogiba
nsogiba's Avatar
Really excited for the first fire up.
Quick Reply: C5 Z06 180 degree header build thread
