Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C5 Corvettes, 1997 - 2004 > C5 Tech
Reload this Page >
DIY: Investigating Sloppiness of the C5 Shifter/Linkage/Trans
Old 08-24-2017, 11:39 AM
nsogiba
CF Senior Member
nsogiba's Avatar
Liked 224 Times in 192 Posts
Originally Posted by nsogiba View Post
Quick update. Trans is back together, while filming that video I briefly talked about how sloppy the shift linkage between the shifter and the trans is (specifically, the u-joint where it connects to the trans via roll pin):
I took a ride to the local specialty hardware store, advance auto, Autozone, and Fleet Pride - nobody even carries a generic u-joint similar to the one welded to the shaft, so it's back to the drawing board. I did some research and found that steering shaft u-joints are fairly similar in size and construction and will see about the same torque as a shift rod linkage. A few minutes later I had this guy on the way:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I don't know whether this is something that can be bolted/roll pinned to the shift shaft, or if I'll have to weld on. I don't see it wearing out in the lifetime of the car. Hopefully it is a true "zero slop" unit.
Update - I ended up using this joint as it is really a great zero slop joint, but had to cut the ends off and weld it to the shift linkage to get it to work. Really happy with it.
nsogiba is offline
The following users liked this post: nsogiba
TastyBacon (08-24-2017)
Old 08-25-2017, 03:11 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Liked 1,329 Times in 1,057 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OUTSTANDING!!! Good job repairing something that most people just live with because there are NO simple GM replacement parts.
Bill
Bill Curlee is offline
Old 08-25-2017, 08:40 PM
frodo84
Overpaid insultant
frodo84's Avatar
Liked 27 Times in 22 Posts
frodo84 is offline
Old 08-28-2017, 08:53 AM
nsogiba
CF Senior Member
nsogiba's Avatar
I dug up some old pictures of my work in case anyone might be curious.
Measuring the old linkage before chopping it up.
The cut and welded U-Joint.
Fluid of choice
nsogiba is offline
Old 08-29-2017, 01:26 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YOU,,,,,,, Do EXCELLENT WORK my friend!
Good job on making it happen!!
Bill
Old 10-17-2017, 03:19 PM
a_ahmed
CF Senior Member
Liked 17 Times in 15 Posts
why doesn't someone manufacture this as an aftermarket piece... since GM screwed it up...
I had a thread on this and no one has a solution... I am not able to weld and do this kind of stuff... and the question is, does this mean it would have to be done with transmission out?... I just had tranny rebuilt and put in MGW flatstick shifter... and this slop annoys me........... spent thousands and still sucks to shift....
a_ahmed is offline
Old 10-17-2017, 04:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hey,,, Picture this:
" A AHMED C5 Shifter Shaft Repair Company"
You would make some good cash!
When can we expect some repaired shafts??
The following users liked this post: Bill Curlee
nsogiba (10-17-2017)
Old 10-17-2017, 04:15 PM
nsogiba
CF Senior Member
nsogiba's Avatar
Send me your shaft and I'll weld in the u-joint, it's gonna cost you though
Trans and torque tube has to come out to remove this linkage. I am surprised that you didn't inspect the linkage while it was out, especially after making the posts and threads regarding this problem. I would have been very easy to inspect.
Since I didn't know the origin of my problem I investigated all components personally to figure out the issue.
nsogiba is offline
Sam Handwich (04-06-2018)
Old 10-17-2017, 08:24 PM
a_ahmed
CF Senior Member
I had a shop repair it... and it was a long story.... parts delayed in shipping and so on... i was carless.... they took it apart twice.... sigh....
a_ahmed is offline
Old 04-06-2018, 10:43 AM
billy mild
CF Senior Member
Liked 17 Times in 16 Posts
Is anyone offering this as a service to fix the sloppiness in the joint?
billy mild is offline
Old 04-06-2018, 10:58 AM
a_ahmed
CF Senior Member
Ya i still want this... Whycant someone jump on this n make it for us..
a_ahmed is offline
Old 04-06-2018, 11:09 AM
nsogiba
CF Senior Member
nsogiba's Avatar
They do, you guys need to search more. I'd offer this service but don't have the time or machinery to crank them out in numbers.
Most people ditch the lower box altogether and go with the MGW shifter, which is the absolute ultimate in shift feel.
nsogiba is offline
Old 04-06-2018, 08:17 PM
  #33
billy mild
CF Senior Member
I was referring to the u joint by the back of the transmission in the bellhousing.
Old 04-06-2018, 09:03 PM
  #34
Sam Handwich
CF Senior Member
Liked 91 Times in 77 Posts
I am going to guess the answer is still:
Sam Handwich is offline
Old 04-06-2018, 09:06 PM
  #35
a_ahmed
CF Senior Member
ya i got the mgw full setup.. great shifter, tight... but the rear end part that connects to it itself is sloppy... not the shifter... but inadvertly it affets the shifter as its the linkage itself...
a_ahmed is offline
Old 04-09-2018, 08:57 AM
  #36
nsogiba
CF Senior Member
nsogiba's Avatar
Correct.
If you have a welder and some mechanical ability you can cut off the old u-joint and modify a universal application steering shaft u joint to work.
Amazon Amazon
nsogiba is offline
Old 04-09-2018, 10:28 AM
  #37
Sam Handwich
CF Senior Member
Correct.
You are an inspiration to us hacks. I have those exact same Channellocks and a very similar tape measure. With your guidance, and my tenacity I think I can solve this.
Woohoo - it just keeps getting better and better.
Old 04-09-2018, 11:02 AM
  #38
nsogiba
CF Senior Member
nsogiba's Avatar
It's really easy to set up once the drivetrain is out of the car. Just use the trans/TT assembly as a jig to make sure it doesn't hit anything.
nsogiba is offline
Sam Handwich (04-09-2018)
Old 04-10-2018, 12:43 AM
  #39
TMODcustoms
Emerging Vendor
TMODcustoms's Avatar
Liked 41 Times in 35 Posts
Great write up. I like what you did with the u joint, I'd imagine it's leaps and bounds better. I thought about making this universal available for sale but you would have to drop the gearbox to replace it. I'm contemplating a whole replacement shaft but I don't know if there would be enough market for it to make it worth doing.
This is the universal I got for the project, samo samo.
great posts, thanks for the great pics !
__________________
TMODcustoms Specialty CNC Products
New ZeroSlop Shifter Linkages
New Clutch, not without a TIGHT LINKAGE!
C5, C6 & C7
Performance Shifter Boxes $145.00 Shipped
5% and 20% Shifters $150.00 Shipped
Linkages $250.00 Shipped
[email protected]il.com
Instagram
facebook
TMODcustoms is offline
The following users liked this post: TMODcustoms
Sam Handwich (04-10-2018)
Old 04-14-2018, 07:43 AM
  #40
Stehen
Junior Member
Liked 0 Times in 0 Posts
Default Universal coupler
What a creative idea, this will be helpful to many! I have one question on the universal joint, where it attaches on the shifter linkage coming out of the transmission, Did you weld the universal joint directly to the shifter linkage or did you use some sort of a set screw pin through a collar thatís welded on to the universal joint? In the one picture it looks like a set screw in a collar, slid over the shifter linkage coming from the transmission.
Stehen is offline
Quick Reply: DIY: Investigating Sloppiness of the C5 Shifter/Linkage/Trans
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
