DIY: Investigating Sloppiness of the C5 Shifter/Linkage/Trans
#41
Great write up. I like what you did with the u joint, I'd imagine it's leaps and bounds better. I thought about making this universal available for sale but you would have to drop the gearbox to replace it. I'm contemplating a whole replacement shaft but I don't know if there would be enough market for it to make it worth doing.
This is the universal I got for the project, samo samo.
great posts, thanks for the great pics !
What was the core issue with the sloppiness? Was it the shifter rod?
#42
What a creative idea, this will be helpful to many! I have one question on the universal joint, where it attaches on the shifter linkage coming out of the transmission, Did you weld the universal joint directly to the shifter linkage or did you use some sort of a set screw pin through a collar that’s welded on to the universal joint? In the one picture it looks like a set screw in a collar, slid over the shifter linkage coming from the transmission.
There is inherent slop built into the centering spring inside the T56. I replaced the spring, which helped, but it's still not as precise as some Honda and BMW boxes I've enjoyed (and probably never will be as good)
