Oil and air filter utopia
Any questions about oil and air filters have been answered by a web site called gm truck central http://www.gmtruckcentral.com according to their research Fram Xtended Guard XGS is one of the best. I assume everyone is using synthetic oil....Right?
And it also shows the worst filters.
Good reading and photos of proof.
Used my first Fram oil filter Xtended Guard last month. It cost more then the A/C's but the turning surface (the part that goes in your hand) is excellent...hope the filter is as good.
P/N Make Model 30um Filtering (wt 5) Overall Build Quality (wt 5) Media Surface Area (wt 1) Media Volume (wt 1) Price Paid (USD) (wt1.5) Final Grade
PF1218 ACDelco n/a F F B A- B- 0.80
EaO24 Amsoil n/a A A- D+ D F 3.02
B1428 Baldwin n/a D B- B- A- D+ 1.99
3510 Bosch n/a C B- A- B- C 2.44
B4361 Carquest n/a D C+ C+ C A 1.99
LF3679 Fleetguard n/a C D+ D+ D+ B 1.75
DL5 Fram Defense C C- C- C- A 2.07
DG5 Fram Double Guard C+ C- C- C- D 1.84
HM5 Fram High Mileage B- D D C- C 1.53
PH5 Fram Extraguard D+ D C- C+ B 2.00
TG5 Fram Toughguard C- C C+ B- C- 1.93
HP4 Fram Racing C- C+ A B- D 2.09
XG5 Fram Xtended Guard A- A C A C- 3.49
OPH1218 Full n/a D C+ A C C 1.89
HP-3002 K&N n/a B A- B+ A F 3.02
PH1218 Luberfiner n/a C- C+ C C B- 2.08
ML1011 Mann n/a B- C- A B C 2.37
MGL9100 Microgard n/a B- D D D+ B- 1.84
M1-302 Mobil 1 n/a B A A- A D 3.27
FL12A Motorcraft n/a D+ C- B C+ D+ 1.65
21060 Napa Proselect C+ B+ B- C A 2.87
1060 Napa Gold C+ A- B- C+ C 2.81
PG4631 Premium guard n/a D+ B+ C D A- 2.34
PPL34631 Proline n/a D C- F D A- 1.49
PO4011 Pronto n/a C+ C N/A N/A A 2.04
L34631 Purolator Classic B B- C+ D+ B+ 2.74
PL34631 Purolator Pure-one C- B+ A- B+ C+ 2.63
30-1218 Royal Purple n/a A A C- F F 3.09
S17 Shell n/a F F F F A 0.44
S5 STP n/a F F B B B+ 0.81
51060 Wix n/a C A- B+ B+ C 2.82
Grades based off general A, A-, B+, B, B-, C+, C, C-, D+, D, F scale
A being the highest grade and F being the lowest.
Better filteration earns a higher grade, better construction earns a higher grade
lower prices earn a higher grade, higher surface area and volume earns a higher grade.
Final grade is calculated the same as a GPA based on the 4 point system
The higher the final grade, generally means a better overall filter.
Catagories are weighted by importance, calculated weights are listed in column heading
Filteration and build quality are somewhat objective so you can make your own judgments
Testing the filters
Check it out. it's not BS.
Not to mention the fact, that there are several filter brands on that list that are not being manufactured by the company whose name is on the label. Royal Purple, STP, Mobil, Amsoil and Shell are but just a couple examples. Champion Laboratories in Illinois manufactures a great many aftermarket (private label) filters, including several on that list. They may each have their own specified/individual componentry, but they are still manufactured by Champ.
I think so. If you hold a new K&N air filter up to the sun you can see daylight holes through the mesh. (This doesn't give you permission to stare at the sun)
Here we go.................AGAIN!!
EDIT.......BTW, that information, as published on the GMtruckcentral site is 6 years old. Things may have changed, since it's original publication.
I think a true test would be to pull oil sample or look at thottle body and see how dirty it is.
