New Thermostatic Oil Cooler Adapter for the C5 Corvette
Supporting Vendor
We have a new bolt-on oil cooler adapter solution with a built-in thermostat available for the C5 Corvette. These are in stock and ready to ship.
The oil lines on this new adapter are located on the front and bottom of the adapter, which provides better clearance for some headers. We also now have the sensor port on top, allowing you to connect the factory C5 oil temp sensor without having to extend the sensor harness.
For the C5, choose the M12x1.50 sensor port option from the drop down to retain the factory sensor.
Here's the link: http://www.improvedracing.com/oil-co...ump-p-785.html
This new oil cooler thermostat also clears the LSX block and fits any rear sump LS engine with a factory style oil pan.
To maximize ground clearance with the Corvette, we recommend using this low profile hose end on the IN port:
Part number is DO-090-10-08 for -10AN lines.
This new thermostat also provides more clearance for the knock sensors on the LS3. We will be switching our C6 Corvette oil cooler kit over to use this new thermostat as well.
