Dropping rear cradle - hard brake line question
I've read a couple different procedures for dropping the rear cradle. My questions is specifically about the hard brake lines.
One procedure made it appear that if I pull the cv half shafts, the hard lines can stay in the car? Is that correct? Are the hard lines attached to the cradle anywhere?
http://redshift.homestead.com/files/...ch_install.pdf
Otherwise, for the hard lines to come down with the rear cradle, there appears to be a disconnect up above the trans/diff? Is that something you can access if you lower the cradle a small amount?
http://tech.corvettecentral.com/2011...-installation/
Thanks.
Thanks.
if your abs module is up front, the hard lines stay, they are clipped to the cradle just pop them out. Make sure you dont snag they while lowering the cradle If you have a older one with the abs module in the back I'm not sure.
I left the hard lines. I assume you're dropping the transaxle too...The way I did it was to support the transaxle ahead of the cradle with one jack, and lowered the cradle with a trans jack. Then used that trans jack to let the transaxle down until I could wiggle it off the engine bellhousing. This required a bit of wrestling with the hard lines to clear the diff but it was nothing serious. When I put the car back together, it was no problem to get the lines back where they belonged and I even managed to clip them back to the cradle with the factory clips.
I disconnected mine above the transmission after lowering the rear cradle and took everything from the engine back out as a unit in order to replace the rear engine cover. It is tight but can be done and isn't that hard. Don't forget to bleed the brakes after you get everything back together.
Good Luck
Good Luck
I just had my cradle down and installed it not an hour ago.
Pull the axles out of the differential.
Hard lines are held to cradle by plastic clips, just lift them a bit and pop the lines out.
Installation is the reverse.
Easy Peasy.
Easy Peasy.
nsogiba (05-18-2017)
Spray the "pointy end" of the clips with silicone spray first, it helps make getting them pushed out a bit easier...
And again, go SLOWLY and keep checking to make sure the lines don't get snagged and bent all to heck. Just from bad personal experience!
Jeff
