N2MB WOT Box Wiring
#61
WOT Install
It would not be a fair comparison to gauge install time with me.
But I would expect 3-4 hours. You have disassemble time and soldering. Also running wires to the PCM in my case. Others have connected to bother wires closer.
nsogiba (10-05-2017)
#63
Ok, install complete. No real issues other than having to make up some wire extensions under the fusebox and at the purple PCM wire. The short nature of the wire makes it extremely tough to solder wires there. Maybe I just suck, but all my joints are strong and water proof now.
Testing impressions - holy crap, where did all this power come from? No lift shift is great but my tires spin on each and every shift. It also takes a ton of getting used to, as in keeping the pedal down during shifts. I was able to blow a couple fireballs on the highway - with the cutouts open (they dump right underneath the transmission) it sounds like a bomb going off under the car. Love it. My next project is to relocate the cutouts to the rear mufflers to make a "bypass mod on demand" so that all gases/flames are routed out the back.
I need new tires
I need new tires
#64
Received 1,261 Likes
can you no lift shift without hitting the limiter with it set to 25ms?... I originally had mine set to 300ms and it seemed too long so I switched to 150ms and that was alot better but I couldn't imagine being able to shift fast enough at 25ms
#65
I need new tires
I need new tires
#66
of course you have to have a good clutch, transmission ect, I also have a couple washers for the venom mod or I forgot whatever it's called to help it shift easier
#67
Had a nice long drive today out in the country and put some more miles on the unit. For some reason I'm not always able to get the "pop" or "bang" when I shift. Foot is fully to the floor.
I am wondering if my TPS voltage isn't set to engage soon enough, or maybe I'm not getting on the throttle fast enough after the shift to start the "cycle" again.
Is it also possible I need to uncheck the "auto" setting for NLS and extend the shift time? My T56 is grouchy on the 1-2 but fine on the rest.
Efx (10-08-2017)
#68
following this
#69
I had originally worked my way down to 75 and I was there for about a year and thought that was about the fastest I could get, I was never able to improve it at the drag strip just seemed there were too many other things to think about but found a place I could go late at night and I basically just practiced the 2-3 shift cause I knew if I could do that then I could do the 1-2, went to 50 for awhile then down to 25
#70
I have a built tr6060, act twin disc, and mgw shifter with 1 washer on the detent and it shifts really smooth and precise but dang 25ms is crazy fast... I usually don't use the no lift shift on 1-2 so I don't break traction too hard but I always use it on 2-3 and 3-4, tried it on 5th once and pegged the limiter and haven't tried that since
I've been using it about 3 years now so have just gotten used to it plus I run in the 1/8 mile so only have two shifts since only going into 3rd gear, once you get used to 75mls then 25 feels about the same, I don't really get to use it on the street since no one ever tries to race me but couldn't imagine trying to use it going into 5th! that's crazy I would be afraid my trans would end up breaking at that speed with my luck, I would be too scared to try!
You shouldn't have any problems with your setup I bet your trans is easier to shift then mine, I have rxt twin, mgw shifter, m12 with billit keys and springs and bronze shift forks
#71
#72
#73
I never tried the auto setting so not familiar with it but you might try 250 or 200 but the lower you go it seems the less chance you have for it to backfire or maybe even try 300 and go down from there, the longer the delay the more fuel buildup and more chance of it backfiring
#74
I'll shut off auto and see how it goes, probably start out at 350ms or so.
#75
a while. Expect a half day.
