Dropping Fuel PSI
The car is supercharged and I am running the Casper hot wire kit, kb bap, and a racetronix walbro 255lph in tank pump. Filter/fpr was replaced when I bought the car 4 years ago.
The first racetronix pump came to me dead in the box. Took me a bit to determine that because I presumed new = working in that case (mostly because I didn't want to bust into the tank again) but that's why it was. I ordered a second same pump, dropped it in, and it instantly ran fine.
Until now.
I've been limping the car on factory tune and injectors until I could get a proper tune for the blower. Went down to see Doug @ECS for that yesterday and we hit a few snags with the fuel system.
First, the 20a fuse for the Casper kit went. Then the 20a fuse for the bap kit. Replaced both with 30a and no issue. Ran the engine up again, but the pump is now dropping psi at 4500rpm.
It looks like a weak pump.
I'll borrow a volt meter and look around. Cross wire the Hobbs kit to test bap, try factory harness on pump.
But any other thoughts on this? Weak ground?
Also, I've only ever used walbro before. I'd the lpe pump just twice the price for a fancy name? What other brands are trusted? Racetronix is off my list.
