c5 a/c control dark, which resistors to solder
i have the unit out and apart, all parts seem to be tight. only weird thing is a black burnt looking area on the display screen, about 1/4 to 3/8 in dia.
Received 1,679 Likes
For some reason, most of the display screens for the C5 HVAC and stock radio that I have seen seem to have a burnt spot that you mention in the bottom right corner, not sure why. It doesn't show when the tinted cover is over it.
Unless you got GREAT eyes and a magnifying glass you might see if you have a cold solder joint. When i took mine apart I SWORE it has to be something else because the solder joints on all 8 resistors looked great but for the hell of it, being it was already apart I re-flowed the solder on both side of all 8. Guess what.............just as bright as the day it was made.
Gary
FX VETTE (06-11-2017)
