caravaggio leather racing seat installation
Does anybody have the installation guide and tips and tricks on installing them?
Running Guns & Moonshine
If these are not the upgraded factory pieces which fold then you'll probably have a mounting plate. Fit the plate the the car bolts first to verify there are holes where you need them. If so, fit the plate to the seat securely and then mount the whole set to the car and bolt those 15mm factory nuts back down tight. Easiest to install seats in coupes or very with the top moved away, but I just ten minutes ago yanked my driver seat without doing so and it's fine.
Tips. Move steering wheel up and out of the way. Leave doors wide open. Windows down. Don't forget to connect the power chord before bolting chair and plate to car.
5minute job
5minute job
