Service vehicle soon message?
Old Aug 1, 2017 | 11:30 PM
Kagnus's Avatar
Kagnus
Default Service vehicle soon message?
2000 M6 70k miles.
Codes are all marked H.
10-PCM P1637 <-- Generator L-Terminal Circuit?
40-BCM B2723 <-- PASS-Key Detection Circuit. Steering wheel lock? LMC5 Mod is installed so this is probably nothing.
60-IPC U1160 <--Loss of Communications with LDCM
A0-LDCM B2284 <-- Battery #2 Fault
Low voltage to the lower door control module or maybe a ground? Battery is new. No malfunctions in the door that I have noticed.
B0-RFA U1096 <-- Loss of Communication with IPC
B0-RFA U1064 <-- Loss of Communication with BCM
B0-RFA U1016 <-- Loss of Communications with PCM
Voltmeter reads fine, battery charges fully. Message appears on ignition. Check the grounds? Solenoid contacts?
They are all H codes so this must be a mild intermittent problem.
I'll clear the codes and then see which one throws first.
brb
Old Aug 2, 2017 | 12:08 AM
Kagnus's Avatar
Kagnus
10-PCM P1637 Throws immediately and goes to history. This some kind of initial voltage issue?
Old Aug 2, 2017 | 05:27 AM
Kagnus's Avatar
Kagnus
YOU AGAIN!!!! YOU ARE AMAZING@#@#@&#%
I updated my profile per your advice.
I will check all of this and update this thread.
Old Aug 2, 2017 | 12:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 8VETTE7
Not really..... These are common issues that come up on the C5 again and again, just to a different owner.
OH STOP!
You ARE AMAZING!
To Service vehicle soon message?
