Power seat wiring diagram
I have an 01 with sport seats. My driver side front up/down is not working.
I have traced all the wires from the two motors but I need a diagram to finish my diagnosis. My service manual has every diagram except the seat wiring!
There are two power wires (red & black) at each motor. Also, each motor has a small 3-wire plug. 5 of the six wires check out with connections to the seat module plug. One wire (gray with black stripe) doesn't check out.
Does anyone have a diagram of the motor wiring?
Thanks!
Thanks!
Follow up question:
I traced all the wiring. Everything checks out from the switch to the SCM box and from the SCM box to the motor. I can directly run the motor in either direction so I know the switch is good, the motor is good and the wiring connecting everything is good.
That leaves the SCM as the most likely culprit. I opened up the box and saw three relays. The wiring diagram shows a total of 6 relays so I assume each relay in the box is actually a double function component?
The circuit board is a dual layer so it's difficult to trace all the paths.
Does anyone have any experience with the SCM box?
Night Owl for life
Received 3,247 Likes
thank you from me as well, Jim. will need that schematic soon.
