Years of 4l60e
Years of 4l60e
I am able to get my hands on a 4l60e from a 97 sierra (detachable bellhousing) for free. Is everything internally the same to where I can build it and put it in my 99 Frc and it fit up? I know I have to get different torque tube, wiring, yada yada.
Also I know you can on the 4l80e can you build it to a manual valve body for shifting?
Can't be used. The case is not the same as it has a bolt area to attach the rear end to the transmission and a seal on the output shaft, the input shaft/stator support are different also. The output shafts are also different lengths and to replace that requires tearing down the transmission about 99%. Sorry...
Nope, cases are different. The bolt pattern where the transmission bolts to the bell housing is different from the bolt pattern that bolts to the transaxle. Also, the "new" transmission has a dipstick and the corvette one doesn't. It has a fill hole. Google is your friend, just look it up. If you're going to rebuild the trans, then just rebuild yours... that solves all the problems.
