Repairing Spinning Rear Cradle Bolt
I was trying to install my Hoosier transmission mount tonight, but when I tried to loosen the rear cradle bolt on the front of the passenger side it just spins. I was able to loosen it by using a set of vice grips, holding the bolt while I turned the nut with a box end wrench (not fun). This should allow me to get the mount in.
I searched the forum and I understand there is a retainer inside the frame (awesome design) that needs to be replaced, but what is the correct way to fix this? Do I go in through frame from underneath the car, or do I come in from the top? What is the part number for the retainer? Any help/pics would be appreciated.
This frequently happens with air tools are used on the cradle nuts. Service manual is very specific on warning against the use of air tools. The head of the bolt has a retainer riveted to the frame. As stated above, you can see what it looks like in the front but the rear has not access without cutting a hole.
Any insight on an approximate location of where to cut the hole?
Pull out the carpet in the trunk. Drop a plumb bob from the both bolts on the same side, to the ground. Draw a line thru the 2 marks and far enough to the rear to clear the rear fascia.
Rig a board so you can drop the plumb bob from the back of the car. have the bob touch your line.
Now you can set a straight-edge parallel with the line and pick up a reference line back into the trunk. I don't recall any markings in the trunk of my FRC when I had to do this. You can make a pretty good sized hole, but BE CAREFUL of harness wires and brake lines with any cuts in the trunk.
RocketRod (10-09-2017)
This seems to happen to a lot of guys, if you can shoot some photos as you do this it might be helpful to others.
Concur on prior owner, I have seen shops use air on the cradle nuts so you never know unfortunately.
I was able to get the Hoosier trans mount in without lower the cradle, or should I say with all the cradle bolts loosened it would go down and I got it in anyways. For now I will just use the vice grips and torque the bolt by feel, but this will be on my list of things to fix this winter.
