Upgrading tire size to 18/19..
Old 10-19-2017, 02:45 PM
C5-Doug
3rd Gear
C5-Doug's Avatar
Default Upgrading tire size to 18/19..
I dropped my 2001 C5 the 1" which is available within the factory settings and I want to upgrade by wheels from the 17" and 19" that came from the factory to 18" and 19" but I don't know if that will cause a problem due to the larger rim size? Can someone help? My tire guy is not sure..
Doug
Old 10-19-2017, 09:11 PM
grantv
grantv's Avatar
If you maintain the overall tire diameter, offset, width, sure.
Going up one wheel size is almost exactly a drop in aspect ratio (3 steps in width does same). Example;
Stock Z front is 265 40 17 = tire OD of 25.3"
Switching to 18; 265 35 18 = tire OD of hey, 25.3"
Your base model front; 245 45 17 = 25.7" (235 wide which is 3 steps narrower = 25.3")
Old 10-20-2017, 05:44 AM
Rob 02
Support Corvetteforum!
Rob 02's Avatar
C6 sizes!
Old 10-20-2017, 07:40 AM
bahamasair
bahamasair's Avatar
I have 275/40 r18 front and 305/35 r19 rear with no problems
Old 10-20-2017, 09:14 AM
bravo29
bravo29's Avatar
C6 rims and tires on mine no issues. Just had to run a 1/4 spacer in rear on extended lug nuts.
Old 10-20-2017, 04:34 PM
C5-Doug
3rd Gear
C5-Doug's Avatar
Thanks kindly. I am a new C5 owner so am unsure about some things.. Appreciate the guidance and the explanation! Doug
Old 10-20-2017, 07:34 PM
twokbolt
twokbolt's Avatar
An upgrade to 18/19 will really improve the looks of the car. I am running 18 x 9.5" wheels up front with a 275/35/18 tire. 19 x 10.5" wheels in the back with 305/30/19 tires.
To Upgrading tire size to 18/19..
Quick Reply: Upgrading tire size to 18/19..
