What 16" drag setup are you guys using? Need advice!!
I've got an 03' Z06 and I'm in the market for some 16" drag wheels i can put bias ply slicks on, because 15" won't fit i I can't afford spindles and wheels. I'm also gonna need some skinnies up front.
I was looking at some race stars, but i can't find 16" wheels. Not sure the offset and width either!
What are you guys running? Needing to keep cost below $800 for wheels.
I really appreciate the help.
What tires are you running? Are they 26" or 28"?
26 x 11.5 x 16 bias ply, I have a set of mickey thompsons and a set of m & h's, I don't think you can get the m/t's in that size any more but you can still get the m & h's
If you can find something for the rear I think you can use gto spares on the front, just make sure you use a bias ply on front if you run bias on rear
In the rear, I am running a set of 16" c4 corvette wheels and MT bias ply 26x11.50. I have to use a 2" spacer because I am not grinding anymore off the knuckle for it to clear.
I am running GTO spares up front with MT ET front runners.
