Anyone have a 2 piece timing cover?
I need to do my oil pump since it only has about 10 psi at idle so I think it’s dying. I replaced the oil pressure sensor already. I want to do a cam later on for for now I tought of doing a 2 piece timing cover to make it easy down the line and not have to remove the steering rack again. I found some on eBay for $50 and seeing what everyone’s experience is with 2 piece timing cover. I will post a pic of the eBay one
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I took my OEM one to a machine shop and had it cut in half. Use some RTV between the two pieces when reinstalling.
Works great.
Works great.
nsogiba (12-16-2017)
Yes, that one shown above from ebay will work, but you have to use an LS2 water pump with it. It sticks out a tad more than the stock timing cover so the stock water pump will not mount in front of it. The LS2 water pump sticks out a tad more than the stock water pump does and mounts up just fine.
I got the one from Classic Industries. Like others said. You need the LS2 pump. It has a pressed on rear cover and allows for the clearance to from the cover. I used extra sealant between the plates. So far all is good.
