Fuel filter access location on 2002 Vette
Received 1,261 Likes
if you have it jacked up high enough to slide under the car or on a lift you can remove it with the wheel still on the car
The fuelfilter is mounted on the frame close to left rear wheel .
ArmchairArchitect (02-01-2018)
release the pressure at the schrader valve first, not that much, have a rag handy. Be careful with the brittle plastic clip that you have to reuse, it cracks easy
Afterwards there some fuel left in the filter itself and the connected fuellines , but not much .
When changing filter I had to move this clips from the old filter to the new one.
Also doublecheck that the files lines at seated properly in their connection .
I started my engine when my car was jacked up to check for leaks , and got one leak due one fuelline where not seated properly i the fuelconnector
Here's a quick video I did when I changed mine (2001). I had the "luxury" of having the drivetrain removed, it gives a better view of the filter location and connections. HTH
The following 3 users liked this post by bigmackloud:
