What breaks when a stock C5 hooks up hard??
C5 friends,
I've got a bone stock C5 I'll begin drag racing this summer, and I'd like to improve my ET via launching before I think about power. It's a manual, and I'd prefer to get really solid launches figured out before I move on to anything else. I can imagine someone suggesting I do power first and then worry about traction... While that makes sense, please respectfully hold that advice, heh. It's been specifically my hobby interest to see how quick a manual C5 might go with nothing more than a really strong launch on good tires. I'm now putting my money into that endeavor.
Ideally, I'd like to just slap on some soft compound radials, leave everything else as-is, and start testing at the track to see how high in RPMs I can launch without breaking loose.
Now, my understanding is that this is a really bad idea, because things break. So my questions are:
- What is the total list of parts that break when launching stock cars in general? (ring & pinion, drive shaft, axles, specific bolts somewhere..??)
- Of this list, which seem most likely to break on our C5s?? What's the weakest link? Has there been observed pattern of our cars breaking one part very often during launch?
- What aftermarket mods help protect all of these various parts? I've heard of a rear-end girdle, but that's the only piece of protection equipment I know of.
Axle shafts are likely first. Second could be the aluminum casing. When you put a large sudden load on the drivetrain, the transmission/differential will bend and break. A transmission brace is needed to prevent this from happening.
Wheel hop is the worst thing that can happen, so preventing this is paramount to keeping things together.
lancedolan (02-06-2018)
There is some very good info on this site that is directly related to your goals. https://www.rangeracceleration.com/Launch_Tips.html
fantastic replies so far - thanks a ton
Note: I do have good experience launching at the track. My old bracket racer didn't make enough power to break itself and I never put sticky tires on it. So, it's the mechanical protection that I'm really newbie on.
Gotcha, just thought it might be helpful because if I recall correctly he raced on a stock rear.
2 Topics to read:
https://www.corvetteforum.com/forums...ood-axles.html
https://www.corvetteforum.com/forums...ak-link-s.html
I would do a ECS or DTE (Hoosier) trans brace, and a Pfadt or DTE trans mount. If you can't find the Pfadt or DTE trans mount, I would do some searches on the Hinson trans mount.
If you don't do the mods C5s are getting a little old, I would re torque the diff to the trans as well as the rear subframe. You don't want the diff walking/wobbling behind the transmission.
http://www.eliteengineeringusa.com/t...que_Values.pdf
[I]Thought I replaced everything that could break at the track but there's always a weak spot somewhere! Traction and HP can find them!
Thats what happened to me. i had just bolt ons and broke the shafts from the diff had that fixed. then did h/c/i and had the torque tube rebuilt with the polyuerathe couplers as well, dte brace, hinson mounts and i put 3.90s in and on my 2nd launch at the drag strip broke the car. thought i broke another shaft from the diff after taking the diff off i broke the trans output shaft into the rear. I was lucky though it didnt tear up the rear.
I have to put my nickel here,on a stock c5 you are not going to break torque tube,or any tranny or pumpkin shaft unless you get some bad wheel hop,period
i run crazy RWHP with no problems, you need to work on your launch before you go to the track.
Breakage
Awesome! This is the wealth of information I hoped for, backed up by empirical stories.
Now that we know what breaks...
What are the remedies?
I think you guys are giving me the exact parts I need, so thank you genuinely for that, but I'm still too unfamiliar to completely understand. I'll try to google around and figure it out myself, but here are my confusions:
- Axle shafts...
do you just replace them with aftermarket shafts? Do just you eliminate wheel hop and then you're good to go? Are there other parts to support/prevent? - Trans output
- Wheel hop... gnharley are wondering the same thing. Is there a 1-purchase bolt on to stop the hop?
- Transmission Brace and Transmission Mount:
- These sound like something to support trans output shaft, but Badazz is saying that he broke his output shaft AFTER installing these.
- Do these prevent wheel hop?
- Something else?
- Torque tube rebuilt with the polyuerathe couplers: Are those the black couplers seen here in
Also, if I seem like a newb, it's because I am haha - it's my first experience with a rear-end transmission config like this. What you're all calling a torque tube I would have called a drive shaft. I'll learn and figure it out like I always do, thanks again gentlemen.
As vettenuts said,when you start building power above 450 thats when things get a bit hairy, thats when you will experience nasty wheel hop that breaks things,get your self a trans brace and some not so cheap axles preferably from the driveway shop stage 5,and you're good to go.
At one time or another everybody experiences wheel hop the brace will keep things together.
Much like everyone else has stated, there are a few items when you really start to make power that will tear parts up..
A drag radial will start breaking parts if you launch it hard. Most vettes at the strip have issues because they just sidestep the clutch at 4k+... This is no good. You will want to slip it to the point of feeling it pull then jump off the pedal quick. A little slip will go along way. A bias ply tire will be much more forgiving on the drivetrain than a drag radial.
As the others have said as well, look into an ecs or dte/hoosier trans brace as shown in the post above mine (exo skeleton). This will keep the transmission and differential from trying to twist and pull from each other.
If you are going to replace the differential mount, (c5 weak point due to only being one) replace it with the pfadt mount. It is orange in color and looks like a wishbone thats been pulled apart. This mount is not only solid, but puts positive pressure on the cradle on either side of the differential/transmission to prevent side to side shake. This will also play a major part in getting rid of wheel hop. Some will say the trans brace will get rid of wheel hop, but it won't... The trans brace is only helping you save your mainshaft of the trans that drives the diff.
As for axles, C5 axles have always been praised for being very durable and most C6 guys make the switch to them because of this. I would not worry about them. I would worry about the output shafts (in the diff that drive the cv axles) breaking first. But, with a softer tire and the correct launching method, this shouldn't be too big of an issue at stock power.
What breaks ? Your bank account . I have a friend and all around his Corvette shop are these , I call them milk crates with C-5 rears in them .. I don't think it's if but when the rear will let go without these better parts braces Etc.. I asked him about all the rears and he said people come in and want 500-6-700 HP and he ask what about the rear : Well I'll just see what is going to happen . Then they show up with a milk create with the rear in it all busted up .. Just saying go with the heavy duty parts or make sure you got a milk crate ..
