What's the cost manual to auto?
04 z06 with LS7 wanting to go from manual to auto is it worth it? or should i find another car. Whats normal cost if i do the labor? thanks
Received 8,919 Likes
I agree. It isn't like the old days where all you had to do was change some mechanical components. Now you have to reprogram everything, may have to run a different wiring harness and then have a bastardized car that isn't worth what you put into it. Sell the car and purchase an auto instead. It will cost you less time and money in the end.
Bill
Bill
It has been done. Is it cost effective? depends on what your car currently has, what you want and how you want to control the automatic.
https://www.corvetteforum.com/forums...questions.html
Seeing as how you have a LS7 and I assume you want to go drag racing, I would take a look at 4L80 or TH400 swaps rather than the stock 4L60E.
https://www.corvetteforum.com/forums...st-review.html
Haven't raced it, just street car but the clutch and shifting is getting old. But i do like the feel of having the power if i need it.Not really looking forward to changing the motor but may have to.
Swapping the motor would be easier than torque tube, trans, wiring, and reprogramming.
A motor swap in a C5 isn't that bad, been there.
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Bill
Bill
Suggestion: Put the original engine in the car to sell it and sell the LS7 engine separately. Take those funds and pick up the car you're now looking for.
Best wishes with this.
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
An auto swap is relatively easy. People that say otherwise, likely have never done it.
There is an extensive thread in the FI section that has a lot of info.
For someone that likes the look of the hardtop/Z06, doing a swap is the only answer if you want an auto.
Best of success to you!
I went the other direction. The forum sold me on how cheap and easy it was. I had an ls2 swap in a sentimental car I got. Ended up costing double( at over $7,000) as expected and taking forever. I don't recommend.
it literally would have cost the same to put a new motor in another car.
Some people have the money, time, tools and talent so it may be worth it to some. If I'd known before hand I would have just sold the car.
Well looks like i be putting the stock engine back in,and keep the LS7 and install it in a auto C6 08 or 09 maybe that would hold more hp.May be hard to find C6 that needs motor.
Depends on the parts you use. I had my 03Z done, spent about 6k on RPM trans & parts, and 2-3k for installation labor & tuning. Absolutely love it stalled auto, and is reversible. I've seen guys do it way cheaper and spend way more on a fancy 4l80. Don't count out the 60e it will hold 1000+hp if built right.
I looked into a swap and priced it out. I priced all top end parts because my new build should make 900 to 1000 whp. It priced out to 14k or so in parts for a 4l60e. Labor should pretty much be same. You can do it cheaper depending on your power, goals and type of racing.
