1997 corvette New TPMS sensors not responding
3rd Gear
Rear sensors weren't working so i bought all four new and replaced them. (TPMS-9479952 Chevrolet Corvette 1997-2000 Tire Pressure Sensors Set) bought them from Hubcap Haven. Anyways i tried learning them using a magnet, didn't work. I even bought a VXSCAN EL-50448 Auto Tire Pressure Monitor Sensor TPMS Reset Tool OEC-T5 and that didn't work either. The tool should have worked since the frequencies for 1997-2000 tpms sensors is 315 mhz which is supposed by the tool. My wheels are aftermarket, would the size or dimensions of my wheel affect the learning process? i cant get the sensors to respond.
Did you purchase OEM sensors or OEM replacment ?
OEM Sensors were made by Schrader and yes , it used radio frequencies and is programmed by a magnet. Some replacement sensor rely on rotation to get them to transmit the signal to program and not a magnet.
https://tpmsdirect.wordpress.com/201...r-information/
If you can't get the first one to "beep".... Try another wheel.. Even though it's not the right position.. Just to get em going.. If you can get all 4 to beep and confirm.. Just drive
around for awhile.. Then later go back and reprogram to the correct position.
Sometimes the front tires are more difficult to recognize.. due to the module being toward
the back of the car.. At least you will know which one might be "bad"
manlopmer (02-15-2018)
I was just looking at there web site. Did you notice that the Mhz value for the 1997 - 2000 TPM they are selling are the same as 2001-2004 ?
I don't know the actual MHz's between 97-00 and 01-04. What i do know is they are completely different and one won't work with the other.
3rd Gear
3rd Gear
Rear sensors weren't working so i bought all four new and replaced thepm. (TPMS-9479952 Chevrolet Corvette 1997-2000 Tire Pressure Sensors Set) bought them from Hubcap Haven. Anyways i tried learning them using a magnet, didn't work. I even bought a VXSCAN EL-50448 Auto Tire Pressure Monitor Sensor TPMS Reset Tool OEC-T5 and that didn't work either. The tool should have worked since the frequencies for 1997-2000 tpms sensors is 315 mhz which is supposed by the tool. My wheels are aftermarket, would the size or dimensions of my wheel affect the learning process? i cant get the sensors to respond.
manlopmer (02-25-2018)
