Drag spindles
Drag spindles
Hi guys! Does anyone know if it's possible to use the stock rear calipers on LG drag spindles and run a 15" wheel like Weld rt-s or vitesse rt?
Sorry to revive an older thread but did you guys have to grind a bunch on the rear caliper? I had to go through about 3 rounds of grinding and it is still close. .080 feeler slides in there but I'm worried it's too tight. Any thoughts?
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I never touched my calipers. I only had to grind the LCA which is well documented.
With the car jacked up, take the leaf spring out. Put the wheel on and place a jack under the tire. When you jack up the tire to simulate ride height, you will see where the LCA hits the wheel.
Good luck.
Good luck.
Good luck.
Good luck.
