Squealing sound
Old 03-19-2018, 09:03 AM
bigdaddytowson
2nd Gear
bigdaddytowson's Avatar
Default Squealing sound
My 2000 C5 is making a squealing noise while running. Believe it's coming from alternator or pulley, sounds like tennis shoes on basketball court. Started a few weeks ago, went away quickly. Now it's full time, anyone else run into this issue or know how to fix it. Thanks in advance
Old 03-19-2018, 10:06 AM
helga203
helga203's Avatar
Default Belt
Check your crack pulley. They start wobbling and they move causing belt squeal .common problem.
bigdaddytowson (03-19-2018)
Old 03-19-2018, 08:08 PM
MikeG37
MikeG37's Avatar
I put a line of paint across the front of my 03's factory balancer that could possibly give me a little warning of the rubber failing.
bigdaddytowson (03-22-2018)
Old 03-19-2018, 08:16 PM
Robrote
Robrote's Avatar
A few things to check. Remove the belt and start the car and rule out the AC belt. While the belt is off, spin the idler pulley, the tensioner pulley for any sound. Also spin the water pump by hand. If you still can't find it, I can't help ya.
Old 03-23-2018, 12:51 AM
My Vette Life
My Vette Life's Avatar
if it's the original or old belt, just replace it. also could be from the moisture.
they sell belt conditioner too
Old 03-23-2018, 01:51 AM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
can only be a few things....belt(s)
tensioner serpentine or A/C
water pump
balancer
if its the balancer it will be obvious, wobbling, rubber bushing protruding
A/C is easy to eliminate by pulling serpentine belt and starting car
tensioner is likely
idler pulleys are least likely
water pump, maybe if high mileage...
To Squealing sound
Quick Reply: Squealing sound
