C5 Cyl.Heads Cam. and headers
Could I get any info. on anyone that has done a Cylinder Head , Cam and header upgrade on their stock C5 ? Looking to get 100 hp. gain on 91 pump gas . Can began to hear a tapping in passenger side Cylinder Head , figure be a good time to put goodies into motor. Any reputable shops in Phoenix , AZ . that anyone has had good service with . C 5 is a base model .48,000 miles . Thanks in advance !
Received 19,293 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Could I get any info. on anyone that has done a Cylinder Head , Cam and header upgrade on their stock C5 ? Looking to get 100 hp. gain on 91 pump gas . Can began to hear a tapping in passenger side Cylinder Head , figure be a good time to put goodies into motor. Any reputable shops in Phoenix , AZ . that anyone has had good service with . Thanks in advance !
The PO made 410 rwhp on a '99 FRC with this combo on the stock LS1 short block (until he broke a piston ring land at the track);
Callaway Honker CAI
LS6 MAF
ported LS6 throttle body
LS6 intake
stock 243/799 (non Z06) heads with .040 Cometic MLS head gasket
226/230 .598"/.608" 113+2 camshaft
fully upgraded valve train with trunion kit
LG Pro LT headers and X-pipe (ceramic coated)
Z06 Ti exhaust
160 degree thermostat
tuned for 93 octane
You would need to trim the ignition map a couple degrees to work with 91 octane.
1luckyVette (04-14-2018)
LPE 430 package-cam, ported and polished heads, ported and polished throttle body and intake. Kooks headers, no cats. 428rwhp. Auto.
