Trunnion Upgrade to CHE
Old Jun 20, 2018 | 10:29 AM
hobobiker's Avatar
hobobiker
Originally Posted by leadfoot4
There's such a thing know as the "Anti-Venom Mod", that was popular in the past. Some people were complaining that their shifters were "too stiff" going through the neutral gate, so a former shop in Florida, called "Anti Venom" came up with the idea of adding a washer (or two) to the reverse gear lock out solenoid on the transmission. This took out some of the effort required to move the shifter, but MAY be contributing to what you're experiencing.
I'm not saying that IS your issue, but I'd start by looking there.
Good to know! I've read about the washer trick, but my mind didn't go there on this problem. I was immediately thinking that the reverse lockout solenoid was either broken or there was a bad electrical connection somewhere. I'll definitely take a look since other mods have been done to this old girl over the years...
Thanks...
Old Jun 20, 2018 | 11:01 AM
Smoken1's Avatar
Smoken1
Originally Posted by ArmchairArchitect
I just had my valvesprings replaced on my stock 2002 Z06, 58k miles. Is replacing the trunions something that would've been very minimal extra labor when already doing the valveprings? If so, I'm sort of regretting not having the trunions replaced at the same time.
It should be a minimal charge. The rockers have to come off to replace the springs
Old Jun 20, 2018 | 11:10 AM
hobobiker's Avatar
hobobiker
Since your rockers were already off, it would have been whatever labor time it took the shop to remove the 16 OEM trunnions and replace with whatever you bought. It took me four hours, but it was my first time doing it and I also messed around with my dial indicators trying to measure valve lift for about 30 minutes. Shouldn't have wasted my time since my dial indicators only have a range of about .250/in.
Keep in mind my time included removing the arms, rotating the engine, removing the trunnions, replacing with new parts, cleaning/reinstalling the valve covers, coil brackets, spark plugs, wires, yada yada yada... I'm sure experienced wrenches can do this stuff much faster than a hobby wrench like me...
Old Jun 20, 2018 | 07:30 PM
StingrayRebel's Avatar
StingrayRebel
yes it would be a minimal charge, maybe a half to one hour extra labor... they are easy enough to do though so you could go back and do them on a weekend when you have time... I admit those che trunnions look damn nice, nicer than the straubs... I like how the bushing also has an oil channel machined into it, there should be no issues at all with oil supply... at the time I did my straubs I don't think che were selling self install kits and your rockers had to be sent in
Old Jun 21, 2018 | 07:44 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Jun 21, 2018 | 08:53 PM
Z.youngg85@gmail.com's Avatar
Subscribing. CHE kit looks like high quality stuff.
Old Jun 23, 2018 | 12:12 PM
JohnnyZee's Avatar
JohnnyZee
That’s when I did mine, although I went with YellaTerra Ultra-Lites instead of the trunion upgrade. (20k miles)
