03Z windshield question
Needed a new front windshield. A friend of mine is a 42 yr Glass Guy - he's seen it all and does all my work.
I had to get aftermarket glass - I'm sure its OK for HUD but not sure if it's 4.8mm (i really don't care about that). He removed the broken OEM glass today and wants to install the replacement tomorrow. He wants to use a 'universal' top seal. Says it'll NEVER leak - and he's probably right. Id does however look a little different and doesn't have the longer 'tongue' that goes under the glass - here's a pic of both profiles.
What are my options here? Order the OEM part (who is the preferred guy here?) or go with the street rod style rubber? Are they easy to get quickly? Do they have the Corvette Tax added?
There is a grove / detail across the top of the OEM part that makes it look a little different and the OEM part is glossy finished.
What would YOU GUYS do??
Thanks for any input.
Thanks for the reply - Do I detect sarcasm?
There's quite a few REALLY sharp guys here - glass might not be their specialty but I know there are some Retired GM engineers here. My Brother and my Son are both active GM engineers - you can just tell em by the way they write.
I'm just worried about that long tongue that goes under the glass - it was put there for a reason. The universal profile doesn't have it - also for a reason.
I think TOO much - Its a curse.
In addition to the top seal question, I’m interested in how clear your HUD display is with a non-HUD windshield. Once the install is complete, I’d really appreciate the follow up to include the windshield manufacturer.
Received 1,679 Likes
I've read the threads and seen the pics of the blurry HUD. I was told that this glass IS the HUD model. I will be setting it in the hole and looking at the display BEFORE any glue gets applied. The glass is $1100 retail - it F'n BETTER be right! I'll be sure to follow up.
Now...
How about the top seal? I've looked at some of the vendors here and they don't show the profile of that piece. For all I know its the universal stuff anyway. I need some advice, he wants to install today. I can hold him off a little though as he knows I want this done once and done right.
Now...
Seems like I bought some time to get this top strip thing figured out. The windshield that he was sent has an antenna in it. Wrong car.
Does anyone know the GM part number for that top strip? I do NOT want to re-use the old one and the instructions say - in step 1 - install a NEW on on the glass.
For those that wanted a follow-up. This is the glass I got. It Mic'd out at 4.8 - 5MM depending where I took the reading and how hard I squeezed. The HUD looks as good as OEM - the PGW glass is stamped HUD so....
I'm not in love with the upper rubber but If I had time I would have gotten the GM part. The job is done and seems to be fine. $100 deductible and BOOM goes the Dynamite!
FX VETTE (06-21-2018)
