A/C wierd
2018 C5 of Year Finalist
St. Jude Donor '14,'18
A/C wierd
The pass side blows harder and colder than driver side. Any ideas??? I know that the pass side can be turned down. With the outside temp in the 80's I had to turn the driver side down from usual 77 to get cold air on left.
Received 1,216 Likes
First, I am not a mechanic. But I try things that others have suggested. So here is my story. I had a similar issue. So after reading all the stuff on these issues within the forum, I did this. First, I detached the negative battery connection for ½ hour. Then I turn the passenger’s temp control (I have duel control option) to the middle, and then I reconnect the negative batter cable. Everything then started functioning properly. Now I NEVER touch the passenger’s temp control. Good luck on finding a solution to yours.
The Rabbi (07-12-2018)
Received 19,293 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
