Map lights issue
Map lights issue
This might be a dumb question but here goes.
(In a C5 Convertible) For some reason my map lights aren't working and neither is my glove box light or vanity mirror lights. I have no manual but checked online for fuse info and have been unable to figure out which fuse they are on.
Are they on a "mini fuse" or a "micro relay" circuit??
Any help on this would be appreciated.
THX!!
THX!!
Received 1,216 Likes
THX!!
THX!!
http://corvette-world.com/article-ca...d-Manuals.html
Hkdonvettes (07-21-2018)
I do know what is on Fuse #2 in the foot well fuse box.
Engine Compartment light
Glove box light
Both vanity mirror lights.
Two Lights on the bottom of the inside rear view mirror. (but NOT the flood light)
As for cause of the fuse blowing it is drawing more than the rated amp of the fuse.(10A)
Likely a short in the wiring to one of the above lights.
Has there been any work or damage recently around any of those lights? That is the easiest way to start the diagnosis process to find the cause. Beyond that it is a time consuming process to chase the wires to each light.
Glove box light
1. First step buy lots of fuses!
2. Unplug glove box light and insert new #2 fuse. She blows!
3. Glove box eliminated. Plug back in.
4. Move to Driver side sun visor. Remove and unplug. Insert new #2 Fuse.....and she blows!
5. Driver visor eliminated. Plug back in and re-install.
6. Move to passenger side visor. Remove and unplug. Insert new #2 Fuse.....Fuse does not blow!!
7. Inspect lines and find that both lines folded over metal tube and showed very slight cut which caused the short.
8. Repair lines and add shrink tube over lines for added protection and reconnect and install.
9. Check ~ Glove box light working, Vanity lights working, map lights working and mirror auto darkening working again!
10. Gremlin vanquished!
Thank you very much for your help!!
Glove box is exactly where I decided to start. I had anticipated a long drawn out search but fortunately I found the issue pretty quick!
