Both driver's side brake lights out with Euro tail lights...
My Z06 has Euro tail lights, which have two bulbs, one for the turn signal (Amber) and one for the brake/tail light.
All turn signals work, all tail lights (running lights) work. But when I press the brake, I get no brake lights out of the driver's side tail lights only. The center brake light pulses every time the brakes are pressed, exactly nine times, then holds solid for as long as you hold the brakes (even minutes).
I'm completely baffled. No CELS, no other electrical problems, no other issues.
If the failure suddenly occurred consider the following. First step: take off the offending left tail light and check its brake tail light - replace if necessary. If that doesn't identify the issue, next see if the electrical connector is fully plugged in. While doing that, you might clean the male prongs - sometimes corrosion invades these plugs and interrupts electrical contact. Third, check voltage at electrical connector and see if its hot when hitting the brakes. If none of those (no cost) steps reveals a problem, post again and we'll deliberate what else you might do. Further diagnostic tests might trigger $$$s for parts. In any event, don't throw parts/money at it until you've isolated the underlying problem(s).
Caution: be sure you replace each tail light unit exactly as it was installed. The inboard units are typically different from the outboard ones. Reversing these could complicate your life.
The Lizzard
Did the brake light failure just happen or has it been there all along? The answer to that question may alter the diagnostic/repair things you want to do.
I've swapped the bulbs; no go. I removed the relay/mod that makes the center tail light blink. No go. Current is getting to the tails for the running lights, but when the running lights/headlights are off, there is no voltage to these outlets when the brake light is pressed. Contacts look completely clean of corrosion/debris, so I didn't bother to scrub them out, but might try that too.
Can you explain the last part, about "exactly as installed?" What are you talking about? Like, not putting the fixtures for the outer bulbs in the inner housings by mistake, or something else? AFAIK the tail/brake bulbs are all the same part number across the back.
Edit: Oh Lord; I'm a moron. LoneStarLizzard was totally right. So, sure enough, there are outer and inner brake+tail light bulbs, The outers are Sylvania 3157 B2, the inners are 3157K. I took the tail lights off to polish off some yellowing over the winter, and must have reversed the bulbs.
Thanks a million! We're 100%!
Glad you resolved the issue. It's miserable when your Vette doesn't work right and you don't know how to fix it.
The Lizzard
