2002 Z06 - Service ABS - Error Codes C1225, C1232, C1233, C1248, U1064
4th Gear
I've been searching on the following error codes that my 2002 Z06 just started throwing. I have owned the car since new......it is garage kept and only has 10k miles. I have reset the codes and they keep coming back each time i drive it. It appears to throw the codes under heavt acceleration . I have searched some on the forums and see various possible reasons but wanted to post up here to see what yaw think? Didn't know if there might be a common ground for all these?
28-TCS - Traction Control System
C1225 RF Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1233 RF Wheel Speed Circuit Open or Shorted
C1248 IPC Indicated Low Brake Fluid
A0-LDCM - Left Door Control Module
U1064 Loss of Communications with BCM
A1-RDCM - Right Door Control Module
Thanks for any help!
Southernhick
Southernhick
4th Gear
Thanks 8VETTE7! I'll take a look at those!
I also found this post with some of the same error codes late last night........ended up being a bad EBCM.
Although it looks like he was not throwing a C1225.
https://www.corvetteforum.com/forums...33-1248-a.html
Guess if i can't find any bad grounds or connectors then i will replace the EBCM.
4th Gear
Thanks 8VETTE7! I will checkout the wiring and connectors on both front wheel speed sensors. Yea....i was hoping it was NOT something like the EBCM. I'll post back after i get a chance to inspect.
4th Gear
UPDATE*******
So last night i disconnected, checked, and re-connected both the LF and RF wheel speed sensor harnesses (4 connectors total). All the connectors looked good.
I drove the vette to the gym tonight.....no codes on the way to the gym as i drove calmly, but on the way home i got it to throw just the C1233 code. Each time it threw the code i would pull over.....check the codes (only C1233) then i would reset and try to get it to throw again. Interesting it was easily duplicated. All i had to do was pull out......nail it in 1st shift to 2nd nail it......then around 65mph it would throw the C1233 code. Did it 4 times in a row. Just throwing the C1233 code.
So i'm think'n replace the RF speed sensor harness......what yaw think?
