turn signal proble
turn signal proble
I have a 2004 C5. I turn my right signal on and it flashes about 4 times and quits, I then turn on my right signal and it doesn't come on at all. Ideas on what is wrong or what to check?
Thx
Rick
Thx
Rick
do the e-flashers work?
Turn signals are routed through the e-flasher switch.
if thats going bad, it will cause the turn signals to go wonky.
inexpensive part, but PITA to replace.
Two halves to the E-Flasher switch. One controls the E-flashers and the other half controls the turn signals. The turn signal side has gone **** up. 4 alternatives to repairing:
https://www.corvetteforum.com/forums...post1589443564
I went with the hyper flasher solution. Easy to install and it works to correct the problem. Had mine for many years with ZERO problems.
Received 19,293 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
