C5 ABS and Traction Control fault
Old Aug 19, 2018 | 09:55 AM
gDickyV's Avatar
gDickyV
2nd Gear
Default C5 ABS and Traction Control fault
I get an ABS and Traction Control fault at approximately 50 mph. It seems to be heat related because when its cooler out the fault happens around 70 mph. I've replaced wheel bearings and this doesn't correct the issue. My dealer has given up un trying to fix this. Does anyone have a solution for this issue?
Old Aug 19, 2018 | 10:36 AM
blackbear bob's Avatar
blackbear bob
Codes ?
