Tired of Hurst Ball...time for a change
Totally get that! Mine is 1 7/8" which is great, but also want a change... still watching.
i wish. The problem is not in the threads, it’s in between the insert and the ball itself. A very slight play, almost imperceptible, is enough to make it rattle like a pair of maracas under WOT.
Im amazed at so many responses from you guys. This forum rocks. I ended up ordering a grippy Delrin one, non-weighted, let’s see how it goes. If I’m not happy I’ll bite the bullet and resort to probably Raceseng or TwistedShifterz later on.
On aftermarket non isolated shifters the hurst ball does rattle but there are ways to fix it so it is not a big deal.
Once I get my new Delrin ball, I might cut down and rethread my shifter later at some point. Having access to a machine shop at work makes it easy for me. How much did you guys cut it down by?
I removed around 1" from the top...
I have used the Hurst "cue ball" shifter **** in several cars including the C5 and even on non-Hurst shifters and custom one-off short throw shifters. I never had a rattle or a loose insert - but then again I always used the included jam nut. I really like the 2-1/4" diameter size (true billiard ball size and the same material), but that is all a matter of personal preference so as always YMMV
Me too. IIRC, I cut it just about at the bottom of the slot for the original locking key. You need to make sure it's cut enough so that your chosen shifter **** can thread all the way down, without the "top" of the shift lever bottoming out inside the ****.
Got my shifter ****, and after driving with it I gotta say I’m a happy camper. Signficantly smaller diameter than the Hurst, I recommend it for those looking for a **** that your palm can wrap around more. Not super grippy but it’s grippy enough, more than the Hurst. It’s Delrin with a satin type of finish. Got it from eBay.
#33
https://www.ebay.com/itm/Engraved-De...0AAMXQySpRQTYJ
Are the threads cut directly into the delrin or is there a threaded metal insert that is pressed into the ****? Is there a jam nut?
#34
Is this the one you got?
