Replaced HVAC control module, fan still only works on high and low settings.
Hi guys, I replaced my HVAC control module and the fan setting still only works on the highest and lowest setting. Anyone have any idea what it could be? This is driving me crazy.
Here is the link to the one I bought https://aescorvetteparts.com/product...l-climate-bulk
[QUOTE=skittlenips;1598022972]My bad, I used the wrong name for the part, I replaced the resistor
Here is the link to the one I bought https://aescorvetteparts.com/product...l-climate-bulk[/QUOTE Did you test it with a meter? What year is you car?
[QUOTE=MarcusMilner;1598022984]
It's a 99, I do not own a multimeter so I'm unable to test it. I'm beginning to believe it's the headunit itself. None of the LED buttons work and I have to press the up button probably around 20x to get it to even blow on the highest setting.
[QUOTE=skittlenips;1598022987]Oh gotcha. I wouldn't have bought a used resistor tho bud. Damn those control heads are pricey.
[QUOTE=skittlenips;1598022987]If you have to hit the up button a bunch of times to get results, that pretty much tells the story IMO. I'd buy a used unit, install. If it doesn't fix the problem, sell it and you're out just a few $. Or keep it regardless and sell the unit with no lights...
