Right Turn Signal Turning On All Lights
Right Turn Signal Turning On All Lights (Solved)
I linked the video down below so you can actually see what’s going on. I searched everywhere to see if anyone had a similar problem but nothing? (2003 Z06)
Some back story, I never had any issues before with any of my lights. One of my friends had a set of halos for the rear of my car and wanted to see what they looked like so we put them in but on the last light the fuse blew. We replaced the fuse for the parking brakes (headlights would pop either). All was back to normal after and I put my stock taillights back in but I think there might be another fuse that said goodbye or a relay. Just checking if anyone had ever encountered a similar issue & knew which fuses it would be.
Received 19,282 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Wire is backwards or they're defective. When replacing my parking light harness, I accidentally reversed the ground and turn signal wire and had the same issue.
Giraffy (10-07-2018)
Solved, ended up being the taillights plugs where reversed. Didnt know that could cause such a big problem but we figured it out after a while of messing around with everything.
