Noise after clutch instal
Hey guys, did a mantic 9000 twin disc clutch this spring on my own. Been driving the car like this as i havent had time to wrench on it.
Heres a video of the noise.
The noise goes away by either pressing down on clutch pedal or just pushing the shifter forward/pulling backward(without depressing the clutch or engaging gear) just some forward or backward pressure.
So im wondering what it could be. And also, i still havent gotten around to installing the Tick Master.
Thanks everyone
Thanks everyone
That's normal that how mine sounds. Just broke it in. 600 miles. So far good
That's how twins sound . My RXT Mcleod was worst.
My old C5 have Spec twin clutch and its sound same. Now i have Centerforce twin clutch and its not make any sound when clutch is off. Its build abit different style than other twin clutch.
I had the centerfroce twin also but that was over 10yeas ago and had the same noise with a **** load of chutter
https://youtu.be/W2kHrQ3L9sM
Thanks everyone
Thanks everyone
Ms4 cam, ARH catless longtubes 1 7/8, Halltech Killer Bee 2 intake,CHE trunnion kit, Manton 3 piece pushrods, Romac 25% underdrive pulley, Meilling HV oil pump, pac dual valve spring kit & TI retainers and this ******* noisy clutch.
Received 1,260 Likes
sounds like a twin disc... does it go away as rpms rise?... mine sounds similar but not quite as loud as yours, after about 1500rpm it's smooth
Yes it does go away as rpm's rise. My car isnt running smooth tho. Rpms are set at 700. Heres another vid showing how the rattle goes away when i put pressure on the shifter.
We told you that's just how twin disks sound normally. If you don't like it, I have some special clutch oil that I can sell you, but it will cost you 99.99$ per oz. It will last approximately 30,000 miles and your clutch will be as quiet as a library.
Because you're forcing your synchros to produce friction (read BURNING THEM UP) trying to stop the turning force of the engine to get into gear. The torque tube shaft is what's actually making all the noise.
700rpm idle sound way too low on that cam and cant get smooth idle. I would rise it atleast to 900rpm, that would also make car shake less and clutch not rattle so much.
