A/C pulley question
Old 11-15-2018, 11:48 AM
99Venom
99Venom's Avatar
Default A/C pulley question
I got this thing a few months ago for what I thought was the deal of a lifetime (seller circumstances). But fixing things seems to escalate faster than my wife's "cheap and fast" kitchen update...... The A/C pulley bearing locked up and took the balancer with it. The "while I am in there" has kicked in for cam upgrade so I will have water pump, radiator, and rack out of the way. My question is that since the pump is still good (clutch turns just not the pulley), can I use a puller while it is still on the car? That way I won't have to evacuate, flush, and replace other things. This is quickly becoming more than the 7600 bucks I got into it FML...
Old 11-15-2018, 08:13 PM
Route99
Support Corvetteforum!
Route99's Avatar
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Not too complicated.
Hopefully these videos will help.
Video Part 1
https://www.google.com/url?sa=t&rct=...q82xyEjCk8Jsx2
Video Part 2
Best wishes with your repair.
Edit: Clarifying the sequence of the videos.
99Venom (11-15-2018)
Old 11-15-2018, 08:56 PM
99Venom
99Venom's Avatar
Video Part 1
Video Part 2
https://www.youtube.com/watch?v=CkZCuFip1K8
It's actually the pulley bearing on the compressor that locked up. not the compressor itself, but the pressed on bearing. The tensioner and idler pulleys are fine.
Old 11-16-2018, 09:05 PM
Route99
Route99's Avatar
Sorry for the non-helpful info.
My guess is that it can be done while in the car especially since you'll have the rack, and other components out of the way.
I ran across some old notes that forum member SteveDoten did this several years ago. He was going to post his work with pics but I could not locate that. Perhaps a note to him will get you the info needed.
Best wishes with this.
And yes, "while you are there" it is a perfect time for a cam upgrade!
To A/C pulley question
Quick Reply: A/C pulley question
