O-Ring Between Diff and 4l60E. Can I use sealant or RTV instead?
Ok, so I got my transmission rebuilt and didnt get that oring. (P/N: 24208660) Link to part
Can I use a sealant to replace this or do I have to get this custom order O-Ring?
I actually found on here in town so went and bought it, 9$ ao my problem has been solved. But the tech at the dealership actually told me that in a pinch the RTV would hold up just as good as the O-Ring, just be a little more messy and difficult to take it apart afterwards.
The thing is, O-rings are designed to work in conjunction with some level of compression,either to the faces or the sides. With a form in place seal there isn't any compression. I imagine it works in some situations, and not in others.
