? pertaining to brake fluid in the power steering reservoir
Veteran
i was pulling maintenance on my car and mistakenly poured a little bit of brake fluid in the power steering reservoir. it was a very small amount. i still needed to add some power steering fluid to top it off. do i need to be concerned? will it do any damage?
thanks
rock
[Modified by ROCKnROLL, 11:52 PM 10/31/2002]
thanks
rock
Re: ? pertaining to brake fluid in the power steering reservoir (ROCKnROLL)
I'm glad I am not the only one that does dumb things.... :D I don't know if it will hurt but I would get something to suck as much fluid out as possible and then add the correct stuff. CHECK to see what to add;i.e., get the right GM power steering fluid, as I believe the Vette uses a synthetic. :)
