oil pressre
Old Mar 13, 2019 | 04:45 PM
rsobrien2001vette's Avatar
rsobrien2001vette
3rd Gear
Default oil pressre
My 2001 Corvette Oil Pressure gauge pegs at 80 as soon as the engine starts. What might be wrong? The car runs fine.
Old Mar 13, 2019 | 08:03 PM
socal96r's Avatar
socal96r
4th Gear
It should be the oil pressure sensor. You can test this by putting the key in the ignition and turning the ignition to the on position, not to the full crank position. Check the oil pressure using the dash information center, and if it reads anything above zero, it's most likely the oil pressure sensor. There are a lot of write ups. Look up oil pressure sensor replacement. It's fairly easy. Pick the method you're most comfortable with.
