Odd: Muted engine on hard lefts
Old Mar 21, 2019 | 08:43 AM
turabo87's Avatar
turabo87
Default Odd: Muted engine on hard lefts
Hi folks,
I think this kind of odd but maybe it's just an exhaust leak that I never noticed before. Under normal conditions, my engine and exhaust sound awesome (for me at least). Not too loud but noticeable, along with noticeable valvetrain noises that resemble a sowing machine. I've never noticed an exhaust leak or hiss. Anyway, under a hard left turn when I start to really pull some G's, my engine noises mute incredibly. As soon as I reduce the cornering force, engine and exhaust sound unmuted again.
Could this be just a leak I had all the time and I never noticed? My thoughts is that maybe under high lateral load the header flanges flatten against the block or maybe it's something else. Thoughts?
PS: I have a JEGS .585/.585 228/230 cam, and exhaust is Texas Speed offroad Long Tube 1-3/4 headers with X pipe, mated to Magnaflow XL mufflers.
FYI: I used Mahle MLS gaskets for the headers, along with ARP header bolts, and I torqued to spec when I installed my headers.
Old Mar 21, 2019 | 05:20 PM
Leftlane_1's Avatar
Leftlane_1
If you had an exhaust leak....you would know! It much louder that when its properly bolted together.
How does your engine/throttle feel when pull this hard turn? Are the RPM's dropping significantly? Maybe the motor is starving for air/fuel. If its normal, than safe to say that's not the problem.
Not trying to get personal, but maybe something with you. Like an inner ear issue, fluid in the ear, etc. I would have someone else ride in the car with you and perform the same type of turn to see if they notice it.
Old Mar 21, 2019 | 06:16 PM
turabo87's Avatar
turabo87
LOL I haven’t heard that one before but who’s to say it’s not that. Anyways, RPMs maintain. I can only hold throttle while cornering this hard bc otherwise it would throw off the balance of the car. Also, this was with a full tank of gas. It’s not a big concern for me, I rarely corner hard but I find it very odd. I’m going to try to record it next time.
Old Mar 21, 2019 | 06:30 PM
gimp's Avatar
gimp
You're not running the oil dry, are you? Extended high-G left turns are what kills these engines, unless you are running extra oil and/or have oiling upgrades, right?
Old Mar 21, 2019 | 07:21 PM
turabo87's Avatar
turabo87
No, I’m actually a bit paranoid on that fact. This was a close 90 turn. Maybe lasted 1-1.5 second the turn. I didn’t take it at high RPM either. Maybe at around 3k RPMs
Old Mar 22, 2019 | 12:02 AM
gimp's Avatar
gimp
My only guess right now is that even though your RPMs stayed up, you let off the throttle to make the turn. Otherwise, I have no idea.
Old Mar 22, 2019 | 12:07 PM
FR-CYA's Avatar
FR-CYA
When I turn left in my C5, lateral forces push the catless x-pipe into the passenger side of the tunnel. This completely changes the tone of my exhaust in the cabin. I need to create some clearance between the exhaust and the inside of the tunnel. It's annoying. Do you have aftermarket exhaust?
Old Mar 22, 2019 | 01:01 PM
turabo87's Avatar
turabo87
No, it's different. The noise level drastically mutes, very different from the noise variation during a decel.
Old Mar 22, 2019 | 01:04 PM
turabo87's Avatar
turabo87
I don't know, maybe that is what's happening. Only happens in serious cornering G's for me. Yes, aftermarket exhaust: Texas Speed Offroad Long Tube 1-3/4 headers with X pipe, mated to the OEM style Magnaflow XL mufflers. I did this install recently when I did my cam build. My exhaust sounds normal otherwise; it doesn't sound like I have any leaks.
PS: We're friends on IG. I'm the one who got the Aully Park steering wheel cover, but I put it with the Alcantara side out and with blue stitching.
Old Mar 22, 2019 | 08:00 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
High Gs activate the Active Handling system which reduces the throttle plate opening to reduce power.
Old Mar 22, 2019 | 08:36 PM
gimp's Avatar
gimp
That's a good idea. Press and hold that button and turn it off, then see whatup
Old Mar 27, 2019 | 05:14 PM
curtbriggs's Avatar
curtbriggs
Default After much thought.
Originally Posted by turabo87
Hi folks,
After much thought.
It's gotta be one or both of these two reasons why you can't hear your loud exhaust. Tire squeal from hi-G cornering or the Police sciren. My advice is either slow down or better yet run straight pipes.
Always glad to help solve weird problems.
Curt
Old Mar 28, 2019 | 07:49 AM
turabo87's Avatar
turabo87
Originally Posted by curtbriggs
After much thought.
Curt
LOL. Good one. No, but seriously, no tire squeal. It might have been a higher G corner but don't assume it was high speed. Maybe 30-40mph. This rarely happens that it doesn't really bother me.
Old Apr 23, 2019 | 01:18 PM
turabo87's Avatar
turabo87
Reviving this old thread because I noticed the "muted engine" yesterday and today. The problem is still there and happens even on U turns. Only when I turn left. Doesn't even have to be a high G left anymore; a semi-sharp U turn will do it. I think I'm gonna take the Vette to my go-to exhaust shop and see if maybe there's excessive left/right play on the exhaust sections somewhere.
Old Apr 23, 2019 | 01:23 PM
FR-CYA's Avatar
FR-CYA
As noted above, this was the same problem I had (have). It got much better when I built some clearance into my X-pipe and floor pan/tunnel. But it's still there. Need more clearance.
Here's one of my earlier YouTube videos showing the problem (Skip to 4'10").:
Here's a video of the sound:
Old Apr 24, 2019 | 09:42 AM
Leftlane_1's Avatar
Leftlane_1
Here's one of my earlier YouTube videos showing the problem (Skip to 4'10").: https://youtu.be/in1_QItpFz4.
Here's a video of the sound: https://youtu.be/YIE2p7FamCk
My exhaust just started doing this also. It's the exhaust vibrating on the tunnel. I'm going to adjust my exhaust clamps to prevent this.
Old May 29, 2019 | 02:49 PM
turabo87's Avatar
turabo87
I FINALLY found and confirmed the problem. Similar to your issue with contact with the torque tube tunnel but in my case the x pipe is actually in a hard interference contact with the left side wall of the tunnel. So under "normal driving" circumstances, I'm actually getting an amplified exhaust sound and vibration due to direct contact between the X-pipe and left side of the tunnel. So what I thought was normal noise all the time was actually not normal but rather pretty amplified. When I make a hard left, the x-pipe is pulled to the right of the car and actually becomes "centered" in the tunnel for that second, hence it sounds "muted" but actually this is what is supposed to be the normal sound. I found the interference when I went to my muffler shop for it, but they were soon to close so I'll have to go back another weekend for them to fix it. They have to take the X-pipe section out and realign it or bash in slightly the exhaust tube or tunnel to build that clearance. I'm afraid I might find the Vette then too quiet after the X-pipe is finally centered....we'll see.
To Odd: Muted engine on hard lefts
Old May 29, 2019 | 02:57 PM
FR-CYA's Avatar
FR-CYA
There was a recent post on fb about ill fitting Texas Speed headers and x-pipes, so I'm apparently not alone here. Not saying they're all bad, but some of us have a batch with interference issues. My resolution is to "massage" my x-pipe rather than the tunnel. I had to massage my header away from my steering shaft too. I hate putting a dent in these things, but I don't have any other way to solve the issue (short of buying another one).
Old May 29, 2019 | 03:05 PM
turabo87's Avatar
turabo87
Yes, the goal is to massage the X-pipe first. I'm afraid that once the shop builds the clearance, my exhaust might sound really quiet for me until I get used to it again. On the plus side, it might lower the volume on some of my valvetrain noises that are channeled directly into the cabin like this.
Old May 29, 2019 | 03:08 PM
FR-CYA's Avatar
FR-CYA
It also might reduce heat inside the interior as well. I would certainly get this fixed.
