Issue with VCM scanner on 99 auto
Ok guys.......Here it goes.....My car - 99 auto- simply does not like being scanned. Call me crazy or whatever, but I know what I'm doing. This morning I uploaded a new tune file in an effort to dial it in as good as possible prior to a dyno tune.....However....Issues arose .....Tell me what I did wrong here, but the end result was a running car with no guages working on the car;s gauge pod and the DIC was useless and stuck on a typical message it normally displays. The scanner was connected at this time and was reading things but maybe not everything, not sure. I tI had to shut the car down and when I still had the DIC message illuminated. I disconneted the battery and with no scanner attached I turned the car on....All seems to be fine....I checked the codes but there were no PCM codes, C or H. There was only the stupid codes that usually show up for no reason....Anyway, here is my procedure and if I did something wrong please let me know....
1) Turn car in ON position (not running) with laptop and VCM Editor opened. All lights were off, doors closed, etc
2) uploaded new file
3) Started car up this time with VCM scanner attached and I cleared LTFT and started to log
4) Car has issue mentioned above...
5) Stopped Logging
5) Unplugged USB from laptop and shut car off
6) Pondered the situation and unplugged the neg bat cable
7) Started car with no laptop attached and it seems to start and idle fine. I have a wideband so I saw the AFR in normal range and all guages, AC, lights, all worked fine.....
So what did I do wrong?????? What can be the issue and has anybody ever seen this?
Thanks, Tony
5) Stopped Logging
Thanks, Tony
Moderator, Tech Contributor
Received 2,124 Likes
With that VCM Scanner thingy can you communicate with all the modules ??...with key ON see if you can ??
Are you able to comm with the IPC ??...if you select IPC and look at live data (I'm NOT familiar with that VCM) can you read live data or does it say "will not communicate" ??...when you connect the scanner you are in essence "joining the club" with all the other modules...your scanner may be the problem...do you have another scan tool to connect to the DLC ??
A couple of days I tried to upload the PCM files to my laptop using VCM Editor and with the engine running (why I don´t know) and suddenly all the gauges died .
After I disconnected the battery the I uploaded the files with ignition on /engine off and the upload went fine .
I guess the PCM serial bus was overloaded for some reason and the PCM needed a reset
5) Stopped Logging
Thanks, Tony
5) Stopped Logging
Thanks, Tony
Here's what I did to fix it: Hook the car up to a jump box or battery tender and verify the voltage before you flash it. If it's not at least 12.5V, wait until it is. Note: You only flash in the run position with the engine off. Flash the factory base tune and verify everything works and there are no codes. If there are codes read and then delete them. Then, (verify voltage) go back and flash your new tune into the car. It should take and have no issues. If I'm not tuning startup I wont "connect to vehicle" in the scanner until the car is running.
If you need any help beyond that let me know.
oelarse (05-18-2019)
I've had this EXACT thing happen when tuning a friend's car. **These cars are super sensitive to voltage when you're flashing them. I wouldn't flash these cars if the voltage is sitting below 12.5V. This is especially true with the 97-99 cars I've seen.**
So voltage was fine...it usually is as the car lives on a battery tender....I was able to tune twice and scan twice today. Both times my radio went out and another thing I noticed is my TPMS sensors freak out while scanning....the last issue which I am unsure if it relYed but only happens today during scanning was dredged code 1255..I cleared it after i took the scanner off and it has not come back yet. It could also be that the cable harness to the ebcm was very tight since the SC install. Some of the harnesses and tranny lines needed to be tweaked. I loosened the harness so hopefully it helps...figures
Received 1,261 Likes
I wonder if this is a problem with the hptuners software, I have the older mpvi and never had an issue like this... have yoj tried contacting hptuners?
So another weird issue.....the good thing is I am making progress on my tune for the sc and such..
But I do need to make a few more tweaks which means more scanning...urgh
