Transmission and differential oil-fill trick
I needed to find a way to put oil into my transmission and differential which I had just drained for service. Squeezing the bottle was not an option. So I came up with this. I turned my compressor regulator down to about 3 PSI. It seemed so little I probably could have blown on a piece of hose and produced as much pressure.
I drilled a hole at the top of a bottle of oil. Cut the lid off square at an ID just smaller than the vinyl tubing I purchased. I then forced the tubing through the lid so that would make a seal. I trimmed the bottom of the tubing so it couldn't get plugged on the bottom of the bottle. I then used a rubber tipped air Chuck to pressurize the bottle once I had the end of the 2-foot tubing in the fill hole for the trans or differential. It works like a champ. Refill the bottle and pump another quart in.
Last edited by K-Spaz; 05-30-2019 at 08:48 AM. Reason: an, not and... voice to text...
The following 6 users liked this post by K-Spaz:
Beer:30 (05-30-2019),
CalF (05-30-2019),
jrprich (06-04-2019),
lunaticfringe007 (06-03-2019),
runner140* (05-30-2019),
and 1 others liked this post.
Received 1,679 Likes
I just filled my diff and trans with re-tasked garden sprayers from Home Depot - one for each type of fluid. Took the spray nozzles off, keeping the wand / triggers on the hoses. Made filling both quite easy!
Received 19,233 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Nice trick thank for posting
(edit)
And no, a tiny piece of plastic isn't gonna do anything in there even if some were to get in.
I was using this technique in 1964 when striking down 55 gallon drums of 2190 tep to the main engine reduction gears aboard a navy oiler. Nice to know it still works.
When doing gear oil I'll throw a small 1 gallon bucket of water in the shop microwave for 8 to 10 minutes and get the water good and hot. Then I put the gear oil bottle or bottles into the bucket for 5 to 10 minutes....makes it super easy to pump and flows great. Very important if you have an unheated shop!!
The following 2 users liked this post by TrackAire:
lunaticfringe007 (06-05-2019),
NSFW (06-06-2019)
